Example: Changing Default Apache Ports
Changing the default HTTP and HTTPS ports of a web server is useful when employing an additional web server for caching purposes. For example, nginx web server listens on the default ports (80 HTTP, 443 HTTPS), serves static content (for example, all requests but PHP), and redirects PHP requests to Apache. In turn, Apache web server listens on custom ports (for example, 8888 and 8999) and serves dynamic content - PHP requests.
To change the Apache HTTP port:
Find all occurrences of the string $VAR->server->webserver->httpPort
and replace them with the required port number enclosed in quotation marks, for example: "3456"
To change the Apache HTTPS port:
Find all occurrences of the string $VAR->server->webserver->httpsPort
and replace them with the required port number enclosed in quotation marks, for example: "4567"
Example
To make Apache listen to HTTP requests on port 3456, and HTTPS on 4567, make the changes described above in all templates.
For example, in domain/domainVirtualHost.php
change to
