reseller_pref: Reseller Limits, Permissions, and Interface Settings
The reseller_pref
CL utility enables the administrator to set and edit the reseller's limits and permissions, and to define Plesk interface preferences (e.g. the default language and skin).
Note: The utility is available since Plesk 9.0.
Usage
Example
The following command updates the reseller account with the login name JDoe as follows: the reseller is allowed to manage log rotation and mailing lists and to create customer accounts. The maximum number of available customer accounts for the reseller is restricted to 20.
Commands
Command | Parameter | Description | Example |
Updates preferences and limits for an existing reseller account. |
To disable changing domain limits for the reseller account with the login name JDoe: plesk bin reseller_pref --update JDoe -change_limits false or plesk bin reseller_pref -u JDoe -change_limits false |
Displays the list of available control panel interface skins. |
To view the list of available interface skins: plesk bin reseller_pref --skin-list or plesk bin reseller_pref -sl |
Displays information about reseller account preferences and limits. |
To view information about preferences and limits set on the reseller account with login name JDoe: plesk bin reseller_pref --info JDoe or plesk bin reseller_pref -i JDoe |
Displays help on the use of the utility. |
To view help on the use of this utility: plesk bin reseller_pref --help or plesk bin reseller_pref -h |
Options
Option | Parameter | Description | Example |
Switches the reseller to Power User mode. |
To switch the reseller with the login name JDoe to the Power User mode: plesk bin reseller_pref -u JDoe -power-user true |
Allows/Prohibits creation domains. Is |
To allow the reseller with the login name JDoe to create domains: plesk bin reseller_pref -u JDoe -create_domains true |
Allows/Prohibits managing physical hosting. Is |
To allow the reseller with the login name JDoe to manage physical hosting: plesk bin reseller_pref -u JDoe -manage_phosting true |
Allows/Prohibits managing common PHP settings. |
To allow the reseller with the login name JDoe to manage common PHP settings: plesk bin reseller_pref -u JDoe -manage_php_settings true |
Allows/Prohibits choosing the PHP version. |
To allow the reseller with the login name JDoe to choose the PHP version: plesk bin reseller_pref -u JDoe -manage_php_version true |
Allows/Prohibits managing PHP safe mode. Is |
To allow the reseller with login name JDoe to manage PHP safe mode: plesk bin reseller_pref -u JDoe -manage_php_safe_mode true |
Allows/Prohibits managing DNS. Is |
To allow the reseller with the login name JDoe to manage DNS: plesk bin reseller_pref -u JDoe -manage_dns true |
Allows/Prohibits managing log rotation. Is |
To allow the reseller with the login name JDoe to manage log rotation: plesk bin reseller_pref -u JDoe -manage_log true |
Allows/Prohibits managing task scheduler. Is |
To allow the reseller with the login name JDoe to manage task scheduler: plesk bin reseller_pref -u JDoe -manage_crontab true |
Allows/Prohibits managing anonymous FTP. Is |
To allow the reseller with the login name JDoe to manage anonymous FTP: plesk bin reseller_pref -u JDoe -manage_anonftp true |
Allows/Prohibits managing Java applications. Is |
To allow the reseller with the login name JDoe to manage Java applications: plesk bin reseller_pref -u JDoe -manage_webapps true |
Allows/Prohibits changing the mail settings. Is |
To allow the reseller with the login name JDoe to manage the mail settings: plesk bin reseller_pref -u JDoe -manage_mail_settings true |
Allows/Prohibits managing mailing lists. Is |
To allow the reseller with the login name JDoe to manage mailing lists: plesk bin reseller_pref -u JDoe -manage_maillists true |
Allows/Prohibits managing system access. Is |
To allow the reseller with the login name JDoe to manage system access: plesk bin reseller_pref -u JDoe -manage_sh_access true |
Allows/Prohibits managing non-chrooted environment. Is |
To allow the reseller with the login name JDoe to manage non-chrooted environment: plesk bin reseller_pref -u JDoe -manage_not_chroot_shell true |
Allows/Prohibits managing subdomains. Is |
To allow the reseller with the login name JDoe to manage subdomains: plesk bin reseller_pref -u JDoe -manage_subdomains true |
Allows/Prohibits managing hard disk quota. Is |
To allow the reseller with login name JDoe to manage hard disk quota: plesk bin reseller_pref -u JDoe -manage_quota true |
Allows/Prohibits backing up and restoring data using the Plesk's storage. Is |
To allow the reseller with the login name JDoe to backup and restore data using the Plesk's storage: plesk bin reseller_pref -u JDoe -allow_local_backups true |
Allows/Prohibits backing up and restoring data using the FTP storage. Is |
To allow the reseller with the login name JDoe to backup and restore data using the FTP storage: plesk bin reseller_pref -u JDoe -allow_ftp_backups true |
Allows/Prohibits backing up and restoring account data using the Plesk's storage. Is |
To allow the reseller with the login name JDoe to backup and restore account data using the Plesk's storage: plesk bin reseller_pref -u JDoe -allow_account_local_backups true |
Allows/Prohibits backing up and restoring account data using the FTP storage. Is |
To allow the reseller with the login name JDoe to backup and restore account data using the FTP storage: plesk bin reseller_pref -u JDoe -allow_account_ftp_backups true |
Allows/Prohibits managing antivirus tool used on reseller's domains. Is |
To allow the reseller with the login name JDoe to manage antivirus tool: plesk bin reseller_pref -u JDoe -manage_virusfilter true |
Allows/Prohibits using Plesk API. Is |
To allow the reseller with the login name JDoe to use Plesk API: plesk bin reseller_pref -u JDoe -remote_access_interface true |
Allows/Prohibits managing domain aliases. Is |
To allow the reseller with the login name JDoe to manage domain aliases: plesk bin reseller_pref -u JDoe -manage_domain_aliases true |
Allows/Prohibits managing additional FTP accounts. Is |
To allow the reseller with the login name JDoe to manage additional FTP accounts: plesk bin reseller_pref --update JDoe -manage_subftp true |
Allows/Prohibits accessing Plesk GUI (as opposite to using Plesk API). Is |
To prohibit the reseller with login name JDoe from accessing Plesk GUI: plesk bin reseller_pref -u JDoe -cp_access false |
Allows/Prohibits managing spam filter. Is |
To allow the reseller with the login name JDoe to manage spam filter: plesk bin reseller_pref -u JDoe -manage_spamfilter true |
Allows/Prohibits managing web statistics. Is |
To allow the reseller with the login name JDoe to manage web statistics: plesk bin reseller_pref -u JDoe -manage_webstat true |
Limits the number of available domains. Unlimited if set to |
To restrict maximum number of domains available to the reseller with the login name JDoe to 100: plesk bin reseller_pref -u JDoe -max_dom 100 |
Limits the number of available domain aliases. Unlimited if set to |
To restrict the maximum number of domain aliases available to the reseller with the login name JDoe to 50: plesk bin reseller_pref -u JDoe -max_dom_aliases 50 |
Limits the number of available additional FTP accounts. Unlimited if set to |
To restrict the maximum number of additional FTP accounts available to the reseller with the login name JDoe to 100: plesk bin reseller_pref -u JDoe -max_subftp_users 100 |
Limits the amount of available disk space. A number without a letter is interpreted as the number of bytes. Unlimited if set to |
To restrict the maximum amount of disk space available to the reseller with the login name JDoe to 100 MB: plesk bin reseller_pref -u JDoe -disk_space 100M |
Sets the amount of disk space upon reaching which notification is sent. |
To set the amount of disk space upon reaching which notification is sent for the reseller with the login name JDoe to 70 GB: plesk bin reseller_pref -u JDoe -disk_space_soft 70G |
Limits the monthly traffic usage. A number without a letter is interpreted as the number of bytes. Unlimited if set to |
To restrict the maximum amount of traffic available to the reseller with the login name JDoe to 100 GB/month: plesk bin reseller_pref -u JDoe -max_traffic 100G |
Sets the monthly amount of traffic upon reaching which notification is sent. |
To set the amount of traffic upon reaching which notification is sent to 70 GB/month: plesk bin reseller_pref -u JDoe -max_traffic_soft 70G |
Limits the number of available mailboxes. Unlimited if set to |
To restrict the maximum number of mailboxes available to the reseller with the login name JDoe to 1000: plesk bin reseller_pref -u JDoe -max_box 1000 |
Limits the amount of disk space that a single mailbox can occupy. A number without a letter is interpreted as the number of bytes. Unlimited if set to |
To set the mailbox quota for the reseller with login name JDoe to 10 GB: plesk bin reseller_pref -u JDoe -mbox_quota 10G |
Limits the number of available web users. Unlimited if set to |
To restrict the maximum number of web users available to the reseller with the login name JDoe to 50: plesk bin reseller_pref -u JDoe -max_wu 50 |
Limits the number of available mailing lists. Unlimited if set to |
To restrict the maximum number of mailing lists available to the resellers with the login name JDoe to 30: plesk bin reseller_pref -u JDoe -max_maillists 30 |
Limits the number of available databases. Unlimited if set to |
To restrict the maximum number of databases available to the reseller with the login name JDoe to 20: plesk bin reseller_pref -u JDoe -max_db 2 |
Limits the number of available Java applications. Unlimited if set to |
To restrict the maximum number of Java applications available to the reseller with the login name JDoe to 50: plesk bin reseller_pref -u JDoe -max_webapps 50 |
Limits the number of available subdomains. Unlimited if set to |
To restrict the maximum number of subdomains available to the reseller with the login name JDoe to 40: plesk bin reseller_pref -u JDoe -max_subdom 40 |
Sets the default interface language for client's control panel interface. The argument of the command must be a valid four-letter language code derived from the language code described in ISO-639-2 and the corresponding country code described in ISO-3166. For example, the Plesk code for the Italian language code is |
To set the default interface language for the reseller with the login name JDoe to Russian: plesk bin reseller_pref -u JDoe -locale ru-RU |
Sets the default interface skin for a reseller's control panel interface. |
To set the skin WinXP Olivegreen as the default interface skin for the reseller with the login name JDoe: plesk bin reseller_pref -u JDoe -skin "WinXP Olivegreen" |
Allows/Prohibits having several simultaneous sessions under reseller's login. Is |
To prohibit multiple sessions to run simultaneously under login of the reseller with the login name JDoe: plesk bin reseller_pref -u JDoe -multiple-sessions false |
Allows/Prohibits choosing a DB server from the servers registered in Plesk, when creating a database. Is |
To allow the reseller with the login name JDoe to choose DB server on which a database is to be created: plesk bin reseller_pref -u JDoe -select_db_server true |
Allows/Prohibits managing remote access for database users. |
Allows or prohibits access to applications catalog for viewing and installing prepackaged applications on sites. |
To allow the reseller with the login name JDoe to access applications catalog and install applications on websites: plesk bin reseller_pref -u JDoe -access_appcatalog true |
Allow activating APS apps using license keys from the Plesk license pool. |
To allow the reseller with the login name JDoe to activate aps applications using license keys from the Plesk license pool: plesk bin reseller_pref -u JDoe -allow_license_stubs true |
Allows or prohibits overriding server-wide security policy on web hosting scripting options, if the policy is set up. |
To allow the reseller with the login name JDoe to override security policy: plesk bin reseller_pref -u JDoe -allow_insecure_sites true |
Allows/Prohibits managing hosting performance. Is |
To allow the reseller with the login name JDoe to manage hosting performance: plesk bin reseller_pref -u JDoe -manage_performance true |
Allows/Prohibits creating customer accounts. Is |
To allow the reseller with the login name JDoe to create customer accounts: plesk bin reseller_pref -u JDoe -create_clients true |
Allows/Prohibits managing limits policy. Is |
To allow managing limits policy to the reseller with the login name JDoe: plesk bin reseller_pref -u JDoe -allow_oversell true |
Allows/Prohibits access to website copying. |
To allow the reseller with the login name JDoe access to website copying: plesk bin reseller_pref -u JDoe -manage_website_maintenance true |
Allows/Prohibits access to the WordPress toolkit. |
To allow the reseller with the login name JDoe access to the WordPress toolkit: plesk bin reseller_pref -u JDoe -manage_wordpress_toolkit true |
Allows/Prohibits access to the WordPress toolkit security features. |
To allow the reseller with the login name JDoe access to the WordPress toolkit security features: plesk bin reseller_pref -u JDoe -manage_security_wordpress_toolkit true |
Allows/Prohibits managing the password-protected directories. |
To allow the reseller with the login name JDoe to manage the password-protected directories: plesk bin reseller_pref -u JDoe -manage_protected_dirs true |
Allows/Prohibits managing the auxiliary user accounts. |
To allow the reseller with the login name JDoe to manage the auxiliary user accounts: plesk bin reseller_pref -u JDoe -access_service_users true |
Specifies limits policy:
Is |
To set limits policy for the reseller with the login name JDoe to strict: plesk bin reseller_pref -u JDoe -oversell false |
Limits the number of available customer accounts. Unlimited if set to |
To set the number of available customer accounts for the reseller with the login name JDoe to 5: plesk bin reseller_pref -u JDoe -max_cl 5 |
Specifies the number of websites that can be created and published with Presence Builder. |
To set the number of websites that can be created and published with Presence Builder for reseller with the username JDoe to 5: plesk bin reseller_pref -u JDoe -max_site_builder 5 |
Specifies the number of mobile site versions that can be created with the external UNITY Mobile service. |
To set the number of mobile websites that can be created under subscriptions of reseller JDoe to 5: plesk bin reseller_pref -u JDoe -max_unity_mobile_sites 5 |
Sets the overuse policy:
To set the overuse policy for the reseller with the login name JDoe to notify: plesk bin reseller_pref -u JDoe -overuse notify |
Allows/Prohibits to manage Presence Builder. |
To allow the reseller with the login name JDoe to use Presence Builder: plesk bin reseller_pref -u JDoe -site_builder true |
