Calculating Statistics from Logs
Plesk calculates traffic usage statistics from logs every day using the statistics
utility.
If you need to recalculate traffic usage statistics, you can run the statistics
utility manually. It is located in the /usr/local/psa/admin/sbin/
(on RPM-based OSes) or /opt/psa/bin
(on DEB-based OSes) statistics
directory.
To recalculate statistics for all domains, run the utility without options or with the --calculate-all
option:
# ./statistics --calculate-all
To recalculate statistics for a particular domain, run the utility with the --calculate-one
option:
# ./statistics --calculate-one --domain-name=<<strong class="placeholder">domain_name</strong>>
