Restoration Utility Commands and Options
Location
%plesk_dir%\bin\pleskrestore<br>where %plesk_dir% is an environment variable for Plesk installation directory. By default, it is "C:\Program Files\Parallels\Plesk\".
Usage
pleskrestore <em><command></em> [<em><arguments></em>] [<em><options></em>]
Commands
Command | Argument | Description |
Restores data from the specified backup. Requires the |
Checks integrity of the specified backup file, which is:
Displays the status of a restoration task while the restoration is being implemented. You can get the task ID using the |
Shows the backup file description. |
Displays help on the utility usage. |
Options
Option | Argument | Description |
Specifies restore level. Required with the |
Specifies list of subscriptions, customer or reseller names for restoring. The object names are listed either in a specified file, one per line, or as the option argument, separated by commas. |
Specifies a list of mailboxes for restoration. The list can be read from a file or specified in a comma-separated list. The format of a list item is Use the additional option |
Specifies a list of mailing lists for restoration. The list can be read from a file or specified in a comma-separated list. The format of a list item is
Specifies a list of databases for restoration. The list can be read from a file or specified in a comma-separated list. The format of a list item is
Specifies a list of files or directories for restoration. The list can be read from a file or specified in a comma-separated list. Paths to files and directories should be relative to the subscription root.
Specifies a list of sites for restoration. The list can be read from a file or specified in a comma-separated list. The format of a list item is
Specifies a list of DNS zones for restoration. The list can be read from a file or specified in a comma-separated list. The format of a list item is
Specifies a list of SSL certificates for restoration. The list can be read from a file or specified in a comma-separated list. The format of a list item is
Specifies the domain name. Used with the |
Restores configuration only (without content). Used with the |
Restores content only (without configuration). Used with the |
Specifies that SSL certificates are from the server pool. Use with the |
Restores Plesk license key from the backup. |
Enables verbose restore mode. |
Enables quiet restore mode. |
Enables debugging restore mode. |
Do not display warning messages. |
Specifies file that describes conflict resolution policies and rules. |
Specifies a backup file to restore. |
Specif parameters file. |
Suspends the sites being restored. |
If you used password protection for a backup, use this option to specify the password. You can also set the password with the environment variable PLESK_BACKUP_PASSWORD, this is a more secure way. |
Allows you to restore a backup without providing the backup password. Note that in this case, some sensitive data will not be restored properly. For example, user passwords will be replaced with random ones, the information about already installed APS apps will be lost, and so on. |
Allows restoring backups that are created on other servers or in Plesk versions earlier than 11.5. Warning: If you use this option, Plesk will restore the backup file even if it is corrupted or modified manually. |
Restores the backup asynchronously, which means it returns the restoration task's identifier, which you can use later to retrieve the task's status. Used with the |
