Retrieving Web Users Settings
Use the get operation to retrieve settings of web users on a specified site. A web user settings have less priority than web user preferences. If you cannot update web user settings - check web users preferences of the site. For more information on the preferences, refer to the Retrieving Web Users Preferences section.
Request Packet Structure
A request XML packet retrieving settings of web users includes the get operation node:
<packet version="1.4.2.0">
<webuser >
<get>
</get>
</webuser>
</packet>
The get node is presented by type WebUserSetInputType (webuser.xsd
), and its graphical representation is as follows:
- The filter node is required. It specifies the filtering rule. For more information, refer to the Available Filters section. Data type: WebUserFilter (
webuser.xsd
Remarks
You can retrieve settings of multiple web users using different filtering rules in a single packet. Add as many get operations as the number of different filtering rules to be used.
<get>
</get>
<get>
</get>
</packet>
Response Packet Structure
The get node of the output XML packet is presented by type WebUserGetOutputType (webuser.xsd
) and structured as follows:
- The result node is required. It wraps the response retrieved from the server. Data type: resultFilterType (
common.xsd
). - The status node is required. It specifies the execution status of the get operation. Data type: string. Allowed values: ok | error.
- The errcode node is optional. It returns the error code when the get operation fails. Data type: unsignedInt.
- The errtext node is optional. It returns the error message if the get operation fails. Data type: string.
- The filter-id node is required. It returns the filtering rule parameter. For more information, refer to the Available Filters section. Data type:anySimpleType.
- The id node is optional. If the get operation succeeds it holds the id of the web user. Data type: integer.
The following nodes are required only if the get operation succeeds:
- The login node is optional. Returns the login name of a web user. Data type: string.
- The ftp-quota node is optional. It specifies the limit of disk space (in bytes) provided for a web user on the server. Data type: integer.
- The asp node is optional. It specifies if the ASP support for Apache is provided. Data type: boolean.
- The asp-dot-net is optional. It specifies if the ASP.NET support is provided. This feature is supported only by Plesk for Windows. Data type: boolean.
- The ssi node is optional. It specifies if the SSI support is provided. Data type: boolean.
- The php node is optional. It specifies if the PHP support is provided. Data type: boolean.
- The cgi node is optional. It specifies if the CGI support is provided. Data type: boolean.
- The mod-perl node is optional. It specifies if the mod_perl Apache module is supported. data type: boolean.
- The mod-python node is optional. It specifies if the mod_python Apache module is supported. Data type: boolean.
- The fastcgi node is optional. It specifies if the fastcgi extension is supported. Data type: boolean.
Note: If a value for a node is "false", it is not nested in the packet.
Samples
Retrieving a web user settings
The following request retrieves settings of the web user with login name abcdef.
<packet>
<webuser>
<get>
<filter>
<login>abcdef</login>
</filter>
</get>
</webuser>
</packet>
Response:
<packet>
<webuser>
<get>
<result>
<status>ok</status>
<filter-id>abcdef</filter-id>
<id>17</id>
<ftp-quota>-1</ftp-quota>
</result>
</get>
</webuser>
</packet>
Retrieving multiple web users settings
The following request retrieves settings of all web users from example.com, and example2.com sites.
<packet>
<webuser>
<get>
<filter>
<site-name>example.com</site-name>
<site-name>example2.com</site-name>
</filter>
</get>
</webuser>
</packet>
Response:
<packet>
<webuser>
<get>
<result>
<status>ok</status>
<filter-id>example.com</filter-id>
<id>17</id>
<login>FirstUser</login>
<php>true</php>
<cgi>true</cgi>
</result>
<result>
<status>ok</status>
<id>18</id>
<login>SecondUser</login>
<ftp-quota>100</ftp-quota>
<php>true</php>
</result>
<result>
<status>ok</status>
<filter-id>example2.com</filter-id>
<id>11</id>
<php>true</php>
</result>
</get>
</webuser>
</packet>
