Starting and Stopping a VPN Connection
To enable a VPN connection from Plesk:
- Go to Extensions > Virtual Private Networking.
- Click Enable.
To disable a VPN connection from Plesk:
- Click Disable.
If you want to disable a VPN connection on a Windows client, close the Connect to VPN dialog box that appeared when you established your connection. When the Windows user logs out, the VPN connection shuts down as well.
