1. Obtain the installer script
    Download the installer script:
    # wget https://autoinstall.plesk.com/plesk-installer
    Enable execution mode for the downloaded installer script:
    # chmod +x ./plesk-installer
  2. (Optional) During installation, Plesk configures firewalld, at which time runtime firewalld rules are lost. To preserve the currently configured firewalld runtime rules, execute the following command:
    # env PLESK_INSTALLER_SKIP_FIREWALLD=1
    However, in this case, you must manually open the ports required for Plesk to operate. You can do it via firewalld or the Plesk Firewall extension.
  3. Make sure port 8447 is open
    Port 8447 is used for accessing the installer GUI. Make sure, this port is open.
  4. Launch the installer with GUI
    Run the script with option --web-interface to launch the interactive installer with web interface for the latest stable Plesk version:
    # ./plesk-installer --web-interface
    image 77219
  5. Access the installer GUI
    In your browser, go to the specified address:
    image 77220
    Use the ‘root’ user name and password.
    Login name: root
    Password: <YOUR_SERVER_ROOT_PASSWORD>
  6. Choose to install a new product
    image 77222
    Click Install or Upgrade Product.
  7. Select product version
    You will see the latest stable version of Plesk available for installing.
    image 77223
    If you run the installer script with option --all-versions, you will be able to choose what version of Plesk to install.
    # ./plesk-installer --web-interface --all-versions
    image 77228
    Click Continue.
  8. Select packages to be installed with Plesk
    image 77224
    Select one of the available installation types. This will determine what packages will be installed with Plesk. Then click Continue to start the installation.
    Alternatively, you can personally select what packages will be installed. To do that, enable Preview components selection and then click Continue.
    image 77225
    Review and edit the list of packages for installing.
    image 77226
    Click Continue. The installation process will begin.
  9. Installing
    image 77227
    You will be able to see the console output directly in the installer web interface. When everything is installed, you will be informed.
    image 77230
Besides installing Plesk, the installer web interface can also be used to add, remove and update components in the same manner.
To learn more about the installation script, run:
#./plesk-installer --help
When the installation process is complete, follow the few simple steps to configure Plesk for work as described here: Plesk Single Server Post-install Configuration.
