Hiding Buttons for Viewing and Purchasing SSL Certificates
You can hide the buttons for viewing and purchasing SSL certificates both through the command line and the Partner API.
To remove the buttons for viewing and purchasing SSL certificates using the command line, run the following command:
C:\Program Files (x86)\Parallels\Plesk\admin\bin\panel_gui.exe" -p -cert_purchasing true
To remove the buttons for viewing and purchasing SSL certificates using the Partner API:
Use the partner10.createKey or partner10.upgradeKey with the API identifier "EXTRAS_BUTTONS_OFF" in the "array of identifiers of upgrade plans" parameter.
For details on these methods specification, please see
http://central.plesk.com/docs/partner-api/1.0, section Specifications of Methods / partner10.createKey and section Specifications of Methods / partner10.upgradeKey
Note: API identifier "EXTRAS_BUTTONS_OFF" also disables the controls related to SSL certificate selling services and the link to the provider's website.
Important: Once you have turned off a feature through the Partner API, there are no documented methods to turn it back on. If you need to perform this reverse operation, please use the web-based user interface, or contact your sales representative.
