Setting Up and Starting Security Scanning
To set up and start regular security scanning:
- Go to Extensions > Watchdog > the Preferences tab.
- Specify how often Watchdog should scan the server for malicious code in the Repeat security scanning menu.
- Click Apply.
Security scanning will start immediately and will repeat in accordance with the settings you defined. By default, security scanning is started at 2 a.m. local time.
To run on demand scanning:
- Go to Extensions > Watchdog > the Security tab.
- Click the Start icon in the Tools group.
Watchdog will update its knowledge base and start scanning. Upon completion, a detailed report will be presented on the screen.
To switch off regular security scanning:
- Select the disabled value from the Repeat security scanning menu.
- Click Apply.
