Template Execution Context
In essence, configuration templates are PHP files which, when executed,
output web server configuration files. The templates are executed in the
environment where the specific variables $VAR
and $OPT
are
available.
$VAR
is an object containing the data model which should be applied
to a template. The variable contains an essential set of parameters
defining the content of web server configuration. The detailed structure
of the array is presented in the Appendix C.
The most important function is IncludeTemplate() which is part of the
$VAR
array. The function allows including templates one into
another, and it is defined as
IncludeTemplate($templateName, $OPT, $metainfo)
where
$templateName
- string denoting name of included template. Required -
$OPT
- an associative array which passes values to a template. Optional -
$metainfo
- an associative array which defines certain aliases in the template context. Optional
The basic function usage is as follows:
## source: default/server.php
<?php echo $VAR->includeTemplate('server/tomcat.php') ?>
A text generated by the included template (server/tomcat.php
) will
be included in the configuration file.
In cases when the text generated by an included template should depend on the context, for example, when iterating over a set of values, it is possible to pass additional parameters to the template.
<?php echo $VAR->includeTemplate('service/php.php', array(
'enabled' => false,
Here, we included the service/php.php
template and passed the value
'enabled' => false
to it. In the template being included the passed
value is available in the variable $OPT
## source: service/php.php
<?php
if ($OPT['enabled']) { // it is required to detect 'enabled'
echo "php_admin_flag engine on\n";
if (!array_key_exists('safe_mode', $OPT) || $OPT['safe_mode']) { // optional parameter 'safe_mode'
echo "php_admin_flag safe_mode on\n";
} else {
echo "php_admin_flag safe_mode off\n";
if(array_key_exists('dir', $OPT) && $OPT['dir']) { // optional parameter 'dir'
echo "php_admin_value open_basedir {$OPT['dir']}:/tmp\n";
} else {
echo "php_admin_flag engine off\n";
The code in this sample will generate two different blocks of text depending on which value of the ‘enabled’ parameter is passed.
Note that $VAR
, which contains the data model, can be used in
templates being included as well. Some values of $VAR
are defined
using the content of $metainfo
. For details on possible
$metainfo
content and how it affects a template context, refer to
Appendix C. For example, by defining the subDomainId
value in the $metainfo
parameter, it is possible to set an exact
subdomain model available at $VAR->subDomain
in a template being
included:
## source: default/domainVhost.php
<?php
//going through all subdomains of current domain
foreach ($VAR->domain->physicalHosting->subdomains as $subdomain) {
if ($subdomain->ssl) { //if SSL/TLS is enabled on a subdomain
//include configuration for subdomain with enabled SSL
echo $VAR->includeTemplate('domain/subDomainVirtualHost.php', array(
'ssl' => true, // passing $OPT['ssl'] = true
), array(
'subDomainId' => $subdomain->id, // define target subdomain for which a configuration file is being built
//include configuration for subdomain with disabled ssl
'ssl' => false,
), array(
## source: domain/subDomainVirtualHost.php
ServerName "<?php echo $VAR->subDomain->asciiName ?>.<?php echo $VAR->domain->asciiName ?>:<?php echo $OPT['ssl'] ? $VAR->server->webserver->httpsPort : $VAR->server->webserver->httpPort ?>"
