Defining Objects for Restoration
Defining objects for restoration includes the following:
- Specifying a source backup file.
 - Defining the level of restored objects.
 - Applying filter on the specified level.
Generally speaking, the data that can be restored with one call of the
pleskrestore utility are represented by any cell of the following
table.
| Restoration levels specified with the -level option | ||||||||
| Server | Resellers | Customers | Subscriptions | |||||
 Selected with the -filter option  |
Selected with the -filter option | Selected with the -filter option | ||||||
| Backup file | <server>.xml | zip | Full restoration | All reseller accounts | Selected reseller accounts | All customer accounts belonging to administrator | Selected customer accounts belonging to administrator | All subscriptions belonging to administrator | Selected subscriptions belonging to administrator |
| <reseller>.xml | zip | Full restoration of a reseller account | All customer accounts belonging to reseller | Selected customer accounts belonging to reseller | All subscriptions belonging to reseller | Selected subscriptions belonging to reseller | |||
| <customer>.xml | zip | Full restoration of a customer account | All subscriptions belonging to customer | Selected subscriptions belonging to customer | |||||
| <subscription>.xml | zip | Full restoration of a subscription |
The source backup file defined for restoration can be of one of the following types:
<info>.xml- backup metadata file, in case of restoring from backup located in Plesk’s storage. -
<backup>.<zip>- archived backup file, in case of restoring from an exported backup.
For example, to restore the whole server backup, you choose a
<backup storage root>\<server> .xml file, or an exported server
backup file. To restore a customer account belonging to a reseller, you
choose a
<backup storage root>\ resellers\ <reseller ID>\ clients\ <customer ID>\<customer> .xml
file.
Defining level of restored objects
Defining level of restored objects allows you to narrow the amount of restored data according to your needs. For example, you may want to restore only subscriptions which belong to a customer or a reseller, skipping all other data not related to subscriptions.
To define the level of restored objects, use the -level option with
appropriate value. The option is required, so in cases when you do not
need any narrowing but just restoring all data from a backup, define the
level equal to the level of file.
To restore entire server:
pleskrestore --restore <backup storage root>\<server>.xml -level server
Note: When the whole server backup is restored, license keys are not
restored by default. To restore license keys along with other server
content, use the -license option in your restore command.
To restore entire server with license keys:
pleskrestore --restore <backup storage root>\<server>.xml -level server -license
To restore all subscriptions and sites belonging to a reseller:
pleskrestore --restore <backup storage root>\resellers\<reseller ID>\<reseller>.xml -level domains
To restore all reseller accounts:
pleskrestore --restore <backup storage root>\<server>.xml -level resellers
To perform a more selective restore, use a filter (the -filter
option) which selects for restoring particular objects of the specified
level (resellers, customers, subscriptions). The objects are specified
by their names, which are domain names for subscriptions, and usernames
for resellers and customers. The specification can be done as follows:
Command line specification. The restore command takes objects
identifiers as values of the
-filteroption defined in the following string:list:<item1>,<item2>,...,<itemN>. -
File specification. The restore command takes the objects
identifiers from the file specified as argument of the
-filteroption. The file must be in plain text format, and object identifiers are separated by line breaks (that is, one identifier per line).
To restore two resellers from a server backup:
pleskrestore --restore <backup storage root>\<server>.xml -level resellers -filter list:JohnDoe,JaneDoe
or
pleskrestore --restore <upload directory>\<server backup name>.zip -level resellers -filter list:JohnDoe,JaneDoe
To restore two subscriptions owned by server administrator:
pleskrestore --restore <backup storage root>\<server>.xml -level domains -filter list:example.com,sample.org
To restore several subscriptions of a customer defined in a file:
pleskrestore --restore <backup storage root>\resellers\SandyLee\clients\JaneDow\<customer>.xml -level domains -filter <path to the file>\restore-subscriptions.txt
