Configuring System for Testing
To test your extension in real-life conditions, install it to Plesk by logging in to Plesk as the administrator and adding the extension on the Server Management > Extensions page. Below you will find Plesk configuration parameters that help you easily debug your extensions. Be sure to comment the parameters (by adding the leading ; symbol) after you complete testing and decide to use Plesk in production.
How to Improve the Verbosity of Debug Information
If your extension uses the Plesk GUI and it exits with an error or an exception, you should see the PHP stack trace. If you do not see it, and, say, see only a blank screen, try to improve the verbosity level of the debug output by adding the following lines to the panel.ini file:
[log]
priority=7
Then, turn on PHP error reporting in php.ini. The file path is:
- (Linux)``/usr/local/psa/admin/conf/php.ini``
- (Windows)``%plesk_dir%adminconfphp.ini``
Open the file and edit the display_errors setting:
display_errors = On
Restart the the web server which handles requests to the Plesk GUI:
/etc/init.d/sw-cp-server restart
How to Prevent Inconsistency Between Code and Results
If you are testing an extension on Linux, you may run across the problem
with inconsistency between your code and expected result. The
inconsistency happens because Plesk content is cached, so the cache must
expire before you see the update. To mitigate this problem, turn the
Plesk cache off. This is also triggered in php.ini by the following
line:
apc.enabled = 0
The change will take effect after you restart the web server which handles requests to the Plesk GUI. The restart command is as follows:
