balancer: Custom Balancer Management
The balancer utility is used to register or reset custom balancers.
Commands
| Command | Parameter | Description | Example |
--register |
Register the custom balancer. | plesk ext plesk-multi-server --balancer --register -class <class> |
--reset |
Reset the custom balancer. | plesk ext plesk-multi-server --balancer --reset |
--help |
Display help on this utility. | plesk ext plesk-multi-server --balancer --help |
