By default, Plesk sets the httpdocs directory as the Document Root directory for all hosted domains. However, many modern web development frameworks presume that a different directory, for example, <app_root>/public is used as the document root. Plesk administrator can change the default Document Root directory by editing the panel.ini file according to the following pattern:
[domainManagement]
docroot = "new_default_docroot"
where <new_default_docroot> is a directory name or a path to a directory (e.g. "new_docroot" or "<domain>/public").
You can use only the following characters in the name of the Custom Document Root:
  • Slash (/)
  • Period (.)
  • Hyphen (-)
  • Word characters:
    • Alphabet letters A-Z (upper or lower case)
    • 0 to 9 digits
    • Underscore (_)
The changes will be applied to all newly created domains, but will not be applied retroactively to existing domains. The path is relative to the webspace root, and you can use the <domain> environment variable that is replaced with the domain’s name on hosting creation.
For example, if you set the value of docroot to "<domain>/public" and then create a new domain named example.com, the domain will have the following Document Root directory:
image-0
image-1
