Automating Administration Tasks with Command-Line Utilities
Plesk command-line utilities are designed to facilitate the processes of
creating various entities in Plesk bypassing the Plesk GUI. Command-line
utilities are executed via command prompt opened in the
%plesk_dir%\admin\bin\
folder (where %plesk_dir%
is a system
variable containing the Plesk installation directory). You can see the
list of available commands and options by running an utility with
--help
or -h
command. For more information about command line
utilities usage refer to Command Line Interface
Reference.
