To configure Plesk user interface settings, such as interface views and language settings, go to the Product Configurations tab in Partner Central, select the required product configuration from the list, and then click Interface Settings in the Plesk server configuration section.
The settings are applied to all Plesk servers whose licenses are associated with the selected product configuration.
For information about interface views, refer to the Plesk Administrator’s Guide, section Interface Views.
For information about language settings, refer to the Plesk Administrator’s Guide, section Setting Up Supported Languages.
Custom View Settings
You can specify the availability of the following items in the Plesk Custom View mode:
  • Items in the Tools & Settings menu.
  • Web hosting tools and settings.
To configure Plesk Custom View settings, go to the Product Configurations tab in Partner Central, select the required product configuration on the left, and then go the Interface Settings in the Plesk server configuration section and click Edit Custom View Settings.
For information about Custom View settings, refer to the Plesk Administrator’s Guide, section Customizing Power User View.
