Samples of Policy Description
The default conflict resolution policies are described in the following XML:
<?xml version="1.0" encoding="UTF-8"?>
<conflict-resolution-rules>
  <policy>
    <timing>
      <resolution>
        <proceed-with-current />
      </resolution>
    </timing>
    <resource-usage>
      <resolution>
        <do-not-restore />
      </resolution>
    </resource-usage>
    <configuration>
      <resolution>
        <automatic />
      </resolution>
    </configuration>
  </policy>
</conflict-resolution-rules>
The following conflict resolution file resolves all configuration conflicts with database mapping. This can be done in case all configuration conflicts beyond default policies appear because a database server defined in the backup is missed on the target Plesk installation.
  <policy>
    <configuration>
      <resolution>
        <rename new-name="host:192.0.2.12:port:3306"/>
      </resolution>
    </configuration>
  </policy>
