Moving the Virtual Hosts Directory
This option allows moving the directory where virtual hosts reside to another location on the same or another partition. Use this feature when disk space is insufficient on the current partition to house new virtual hosts, and you want to move them all to a new, larger volume.
To move the virtual hosts directory to a new location, follow these steps:
Log in to the Plesk-managed server as a user with administrator rights by using Remote Desktop.
In the Windows Start menu, select All Programs > Plesk > Plesk Reconfigurator. The Reconfigurator application window opens.
Select the Change Virtual Hosts location option.
Specify the destination directory name. If the directory does not exist, it will be created.
Click Next.
During this operation all Plesk’s services will be restarted.
