Installing Plesk for Linux in Unattended Mode
Obtain the installer script
Download the installer script:
# wget https://autoinstall.plesk.com/plesk-installerEnable execution mode for the downloaded installer script:
# chmod +x ./plesk-installer -
Launch the installer with necessary options
To install Plesk without requiring any user input, run the installer script providing all the necessary information through the corresponding options:
# sh ./plesk-installer install <RELEASE> <OPTIONS>
The following parameters are used to define the specific Plesk release you wish to install.
| Parameter | Use | Explanation |
| Product ID | install plesk |
‘plesk’ is the product ID for Plesk. Install the recommended set of components of the latest generally available release of Plesk: # ./plesk-installer install plesk If no product ID is specified explicitly, ‘plesk’ is used by default. |
| Release version | install PLESK_18_0_71 |
Specify the release by the exact release version. # ./plesk-installer install PLESK_18_0_71 |
| Release ID | install PLESK_18_0_71 |
Specify the release by the release ID. # ./plesk-installer install PLESK_18_0_71 Use the list-all command to view all the available release IDs: # ./plesk-installer list-all |
The following options are used to specify additional information.
| Option | Use | Explanation |
--source |
or
Packages source options define the location where the installer
should obtain the Plesk packages for installation. You can use
either For information on managing local mirror repositories, see Mirroring Plesk Autoinstall Servers. |
--preset |
--preset <PRESET> |
Choose one of the predefined sets of components for installation: Recommended, Full, or Custom. # ./plesk-installer install PLESK_18_0_71 --preset Full |
--with |
--with <COMPONENTS> |
Add listed components to the selected preset. # ./plesk-installer install PLESK_18_0_71 \ --preset Full --with git docker |
--without |
--without <COMPONENTS> |
Exclude listed components from the selected preset. # ./plesk-installer install PLESK_18_0_71 \ --preset Full --without java |
--components |
--components <COMPONENTS> |
Install only listed components. # ./plesk-installer install PLESK_18_0_71 --components panel postgresql Use the # ./plesk-installer list PLESK_18_0_71 --components |
To view the available installer commands, run:
# ./plesk-installer help
To view information on the extended option-based interface, run:
# ./plesk-installer --help-options
Example 1: Installing Plesk from a mirror, specific components
The following command installs Plesk Obsidian 18.0.71 (release ID is PLESK_18_0_71)
from a mirror set up on the server mirror.example.com accessible via HTTP.
The installation files will be temporarily stored in /tmp/panel.
The installed components are the base Plesk packages, the PostgreSQL server, and the SpamAssassin spam filter.
--source http://mirror.example.com/ \
--target /tmp/panel \
--components base postgresql spamassassin
Example 2: Installing Plesk on a number of servers, recommended configuration
This script performs a typical installation of the latest Plesk version on the specified servers.
#!/bin/sh
SERVERS_LIST="node1.example.com node2.example.com"
for current_server in $SERVERS_LIST; do
ssh -f root@$current_server 'wget https://autoinstall.plesk.com/plesk-installer -O - | sh /dev/stdin \
--source https://autoinstall.plesk.com/ \
--target /tmp/plesk-installation \
--preset "Recommended"'
done
