Content Management Systems
Content Management Systems (or CMS) are third-party applications that provide a graphical user interface for adding and editing website content: pages, scripts, files, multimedia content, and so on. The following CMS are the most popular and widely used:
  • WordPress - a free and open-source blogging tool.
  • Joomla - a free and open-source content management system for publishing web content.
  • Drupal - a free and open-source content-management framework
Before you can create a website with a CMS, you need to install the CMS on your hosting account. There are two options available:
  • Install a CMS as a web application. All most popular CMS can be installed as web applications using the Plesk interface. To do so, follow these instructions:
  1. Go to Applications.
  2. Find the CMS you need in the list of available applications, and install it as described in the Web Applications section.
  3. Create your website in the CMS. For information about creating websites with your CMS, refer to the relevant documentation.
  • If the desired CMS cannot be found on the list of available web applications, you need to download and install it according to the installation instructions provided in the documentation of the CMS of your choice.
Note: You can install a CMS as a web application only if your hosting subscription allows it.
Caricare contenuto mediante FTP
FTP fa riferimento al "File Transfer Protocol", un metodo di trasferimento di file su Internet. Per caricare file tramite FTP, è richiesto un programma speciale chiamato client FTP. FileZilla è un client FTP gratuito e affidabile. È possibile scaricarlo qui:
https://filezilla-project.org/download.php?type=client
La relativa documentazione si trova qui:
https://wiki.filezilla-project.org/Documentation
Certamente, si è liberi di usare un client FTP diverso. Per connettere a un server FTP, occorre la seguente informazione:
  • Indirizzo del server FTP. L'indirizzo FTP deve essere ftp://your-domain-name.com, dove your-domain-name.com rappresenta l'indirizzo Internet del tuo sito.
  • Nome utente FTP. È identico al tuo nome utente di sistema. Tieni presente che il nome utente di sistema potrebbe essere diverso dal nome utente che usi per accedere a Plesk. Per sapere qual è il tuo nome utente di sistema, vai su Siti Web e Domini e fai clic su Accesso a Hosting Web. È presente presso Nome Utente. Puoi cambiare il tuo nome utente di sistema se lo desideri.
  • Password FTP. È identico alla password del tuo utente di sistema. Se non sai qual è la tua password utente di sistema, vai su Siti Web e Domini e fai clic su Accesso a Hosting Web. È possibile reimpostare la password sotto la voce Password.
Per pubblicare un sito web mediante FTP:
  1. Connetti al tuo spazio web sul server con un programma client FTP, utilizzando il nome utente e la password dell'account FTP.
    Abilita la modalità passiva se sei dietro un firewall. Consultare la documentazione del client FTP per sapere come entrare nella modalità passiva.
  2. Carica i file e le directory del tuo sito sulla directory httpdocs. Se si utilizzano script CGI, è necessario salvarli nella directory cgi-bin.
  3. Chiudi la sessione FTP.
È anche possibile configurare account FTP aggiuntivi se devi collaborare sul contenuto del sito web con altri utenti. Per maggiori informazioni, consultare la sezione Aggiungere account FTP.
Caricare del contenuto con File Manager
Watch the video tutorial
" target="_blank">Guarda il video tutorial
Per caricare un sito web da un tuo computer sul server Plesk mediante File Manager, seguire i seguenti passaggi:
  1. Sul tuo computer, aggiungi la cartella contenente i file del tuo sito web a un archivio (fai clic destro sulla cartella e seleziona Invia a > Cartella compressa (zip)) nel menu contestuale.
  2. Nel Pannello del Cliente, vai su File e fai clic sulla cartella httpdocs per aprirla, fai clic su Carica file, seleziona il file di archivio e fai clic su Apri.
  3. Quando il file sarà caricato, fai clic sulla casella di controllo accanto e seleziona l'opzione Estrai file .
Se desideri modificare le pagine del tuo sito web, puoi farlo con File Manager. Mette a tua disposizione un editor HTML che permette la modifica visiva di pagine HTML (senza necessità di digitare tag HTML manualmente). Per modificare un file nell'editor HTML, posiziona il puntatore del mouse sopra il file, fai clic su per aprire il menu contestuale del file e seleziona Modifica nell'Editor HTML.
Puoi anche modificare dei file nell'editor di testo File Manager. Per aprire un file nell'editor di testo, fai clic su per aprire il menu contestuale del file e seziona Modifica nell'Editor di testo.
Se hai file o pagine web che desideri rendere inaccessibili su Internet, cambia i permessi di accesso a questi file in File Manager. Per modificare i permessi di accesso per un file o una directory, fai clic su per aprire il menu contestuale e seleziona la voce Cambia permessi. Per maggiori informazioni sulla revisione e la modifica di permessi, consultare la sezione Definire i permessi di accesso a file e directory.
Per maggiori informazioni sul caricamento e la modifica dei file e le cartelle del sito web con File Manager, consultare la sezione Contenuto del sito web .
