  Hosting Plans and Subscriptions
A hosting plan is a set of hosting resources and services you offer to your customers. For example, the properties of a hosting plan define the server resources available in a plan subscription, such as disk space, traffic, number of mailboxes and so on. To learn more about how plan resources are allocated in the subscription, refer to the section Relationship Between Plans and Subscriptions.
This section will guide you through the process of creating a hosting plan and starting to serve your customers.
The amount of resources and services provided with a subscription can be extended by associating the subscription with add-on plans. To learn how to create add-on plans, refer to the section Setting Up Add-on Plans in Plesk.
