For easy access to Internet resources from the Plesk interface, you can create custom buttons that will be displayed in Websites & Domains of customers and resellers, or on your Home page. You can use this functionality, for example, to provide a link to your company’s website, to a helpdesk, or to a custom web application. Clicking a custom button takes the user to the pre-configured address. Additional information, such as the user’s contact name, subscription ID, or FTP username and password, can be passed along as well. The custom buttons can be reserved for your personal use, or shared with other users and resellers.
To add a custom button, go to Tools & Settings > Custom Buttons (in the Plesk Appearance group) and click Add Link to Service. Configure your custom button with the following parameters:
  • Show to me only. Select this checkbox if you want the custom button to be shown to you only. Leave the checkbox cleared if you want the custom button to be shown to you and all other users and resellers.
  • Location. This setting determines the placement of the custom button. Choose from the eight available options, depending on whether you want the button to be displayed for subscription users, for resellers, or for yourself only:
    • Common Access. The custom button will appear on the Websites & Domains page, in the Additional Services section of the Navigation Pane on the right:
      image 74622
      It will also be available in the section containing links to other Plesk functionality, such as databases and backups:
      image 74623
      Users logged in with an administrator’s or reseller’s account will also see the button in the Navigation Pane, in the Links to Additional Services section.
      image 74630
    • Website Tools. The custom button will appear on the Websites & Domains page, on the ”Custom Services” tab:
      image button website tools
    • Websites & Domains page of Subscription. The custom button will appear on the Websites & Domains page, in the section of the Navigation Pane containing links to other Plesk functionality, such as databases and backups:
      image 74625
    • Customer’s Home page. The custom button will appear on the Websites & Domains page, in the Additional Services section of the Navigation Pane:
      image 74626
    • Reseller’s Home page. The custom button will appear on the Home page, in the Custom Buttons section:
      image 74631
    • Reseller’s Tools and Utilities page. The custom button will appear on the Tools & Utilities page, in the Additional Services section.
      image 74632
    • Administrator’s Home page. The custom button will appear on the Home page, in the Custom Buttons section:
      image 74633
    • Administrator’s Tools & Settings page. The custom button will appear on the Tools & Settings page, in the Additional Services section.
      image 74634
  • Priority. This number helps define the order in which custom buttons are displayed. The lower the priority value, the closer the button to the top of the list (the buttons are ordered left-to-right in the website tools area, top-to-bottom otherwise). The custom button with the lowest priority value is displayed first, and the one with the highest is displayed last. If you only have a single custom button, this setting has no effect. Custom buttons with identical priority values are ordered alphabetically.
  • Background image. Square images work best. We recommend using a 16x16 pixels GIF or JPEG image for buttons placed in the navigation pane, and 32x32 pixels GIF or JPEG image for buttons placed in the website tools area.
  • URL. Type in the target URL, starting with http:// or https://. Select one or more checkboxes below to have Plesk include certain information about the user or the currently selected subscription in the URL.
    • Open URL in Plesk. Select this checkbox if you want the target URL to open in the currently active browser window. Leave the checkbox cleared if you want the target URL to open in a new browser window.
    • Do not use frames. Select this checkbox if you want the target URL to open replacing the Plesk interface. Leave the checkbox cleared if you want the target URL to open within the Plesk interface.
To change the properties of a custom button, go to Tools & Settings > Custom Buttons, then click the name of the button you want to modify. To remove one or more custom buttons, select the corresponding checkboxes and click Remove.
