If your hosting plan supports multiple domains, you can add new domains to the server easily. Before adding a domain like example.com, make sure it’s registered. If your hosting provider offers domain registration, you can do it from the Customer Panel. Otherwise, register the domain with an external registrar first.
In Plesk, you can configure two types of sites:
  • Second-level domain websites (like example.com), which can include:
    • Unique domain name and optional aliases.
    • Subdomains (for example, mail.example.com).
    • FTP accounts with directory-level access.
    • Content creation with Sitejet Builder.
    • Easy app deployment (CMS, blogs, shopping carts, and more).
    • SSL/TLS for secure data exchange.
    • Mail services and mailing lists.
    • Statistics on traffic.
  • Subdomains (third-level domains), which typically represent sections of an existing site. They support:
    • Separate document root.
    • FTP access.
    • Easy app deployment.
Adding More Domains
To host a new website with a second-level domain name:
  1. Go to Websites & Domains and click Add Domain
    image 76850
    Muista
    The options available on the Add Domain screen may vary depending on your Plesk edition.
  2. Choose one of the options for creating a website:
    • Blank website - Start with a simple placeholder page for your HTML or PHP site.
    • Upload files - Upload your own website files from your local computer.
    • Sitejet Builder - Create a website with our drag & drop website builder. Find out more at Sitejet Builder.
    • Deploy using Git - Pull your website files directly from a Git repository. Find out more at Git Support.
    • Wordpress - Set up a site running the latest WordPress version. Find out more at WP Toolkit.
    • Mail hosting - Create a new domain for mail hosting only.
  3. Under the ”Select your domain name” section, choose:
    • Registered domain name if you already have a domain. Enter the domain.
    • Temporary domain name if you do not have a registered domain name. Plesk generates a temporary domain name that you can use before you register and purchase a proper domain name.
  4. Under the ”Webspace settings” section, choose one of the following:
    • Create a new webspace and fill in the required details.
    • Select an existing webspace. In this case, choose the hosting type and its respective settings. Find out more at Hosting Types.
  5. Click Add Domain.
    The new domain name is now shown in the list at the bottom of the screen.
  6. If the operation of changing hosting settings is available for your account, then you can click the domain name of the new website to view or change the hosting settings, as described in the section Changing Hosting Settings.
Based on the option you selected for creating your site, you can now start building it (for example with Sitejet Builder or by uploading your web content to the subscription of the new website, as described in the section Website Content).
Muista
If Plesk cannot resolve your domain when you create it, you will see a warning message in your domain’s **DNS Settings** interface (Websites & Domains > Hosting & DNS > DNS). Connect the DNS settings related and your domain name with the domain name at the registrar’s side. To achieve this, enter the Plesk name server IP address into the respective NS record of the registrar. The instruction on how to obtain the IP is as follows: go to Websites & Domains > domain name > Hosting & DNS > DNS, find the NS record, and then find the A record corresponding to the NS record value.
For example, if your NS record is
example.com. NS ns.example.com*,
find the A record with ns.example.com, for example,
ns.example.com. A 192.0.2.12
The resulting value, 192.0.2.12, is the Plesk name server’s IP that you need.
Choosing a Domains View Mode
The ”Websites & Domains” screen looks differently (the layout, visible controls, and the overall UX) depending on the domain view mode you choose.
To choose the view mode, go to Websites & Domains, click Set view, and then choose:
  • In an expanded row view is an expandable list best suited if you have several domains and you want to have access to all available controls.
  • On a separate page view is good if you have a large number of domains (more than 100). However, not all necessary controls will be visible.
Adding a Domain Favicon
A domain favicon is a small image Plesk shows next to a domain name. You can see favicons on the following screens:
  • (For Power User view) Websites & Domains
  • (For Service Provider view) Domains and Subscriptions
Once you create a domain, Plesk generates and shows a default favicon based on the first two characters of the domain name.
image default favicon
However, you can add your custom favicon, for example, the same one you use as your website favicon shown on the browser tab. Custom domain favicons help you to do the following:
  • Find the desired website more easily.
  • Tell one domain from another.
To add a Dynamic List domain favicon:
  1. Choose a PNG, SVG, or ICO image you will use as the favicon.
  2. Give the favicon image any of the following names:
    • favicon.svg
    • favicon.ico
  3. Using File Manager, upload the image to one of the following website directories:
    • The document root directory, which is, by default, httpdocs (unless you set a custom document root)
    • /images in the document root directory
    • /assets/images in the document root directory
    image favicon location
    Muista
    It is essential that you upload a favicon to one of the directories mentioned above. To show a custom favicon, Plesk non-recursively searches for exact file name matches in the directories. If you upload the favicon.svg file to the /images/favicon directory, Plesk will not find the image because /images/favicon is a subdirectory of the required directory.
You have uploaded your custom favicon image. To have Plesk show your favicon, wait a while or refresh the Plesk page.
image custom favicon
Muista
If your website runs on WordPress, you can create both the website and domain favicon at the same time using the Favicon by RealFaviconGenerator plugin. Plesk detects a website favicon created by the plugin wizard and automatically sets the favicon for the domain in Dynamic List view.
For Plesk to find a favicon, you need to correctly name a favicon image and put it into the designated directories as described in the procedure above. However, you can set custom location and custom name for a favicon using the panel.ini file.
To set a custom location for the Dynamic List domain favicon:
  1. Open the ”panel.ini” file for editing, which is located here:
    • (Plesk for Linux) /usr/local/psa/admin/conf/panel.ini
    • (Plesk for Windows) %plesk_dir%admin\conf\panel.ini
    You can also edit the file in the Plesk interface using the Panel.ini Editor extension.
  2. Add lines of the following pattern and save the file:
    [domainManagement]
    favicons.customPaths[] = path/to/custom_favicon_name.ico
If you set a custom location for a favicon, favicons generated by the Favicon by RealFaviconGenerator plugin will stop working. To bring them back, you need to add the default custom path for Favicon by RealFaviconGenerator:
[domainManagement]
favicons.customPaths[] = path/to/custom_favicon_name.ico ; your custom path added earlier
favicons.customPaths[] = /wp-content/uploads/fbrfg/favicon.ico ; default custom path for Favicon by RealFaviconGenerator
If you do not want to see any domain favicons (neither custom not default ones) in Dynamic List view, you can disable favicons.
To disable Dynamic List domain favicons:
  2. Add the following lines and save the file:
    [domainManagement]
    favicons.enabled = false
Moving Domains
You can move the following:
  • An add-on domain (which is a domain created after the first subscription’s domain) to an existing or a new subscription. An add-on domain moved to a new subscription becomes the main domain of the new subscription.
  • A main domain (the first subscription’s domain) to an existing subscription. A main domain moved to an existing subscription becomes an add-on domain of this subscription while the source subscription is removed.
Moving includes your domains and subscriptions as well as those that belong to your customers and resellers.
Moving an add-on domain to an existing subscription helps do the following:
  • Reallocate domains between customers and resellers.
  • Properly allocate domains after migration from earlier Plesk versions and other web hosting panels.
  • Keep staging websites separately from production ones and then move websites from development to production.
  • Move domains created by mistake to the right subscription.
  • Use subscriptions’ resources more efficiently.
Moving an add-on domain to a new subscription is useful in the following cases:
  • You want to split a subscription that has several domains to sell one of the domains.
  • A subscription is close to the limit of allowed resources.
  • You need to isolate a domain whose security was compromised.
By moving a main domain to an existing subscription, you can merge several subscriptions into one, which helps do the following:
  • Use resources more effectively.
  • Manage one subscription instead of several.
  • Rearrange domains scattered between subscriptions during migration.
A domain is moved to another subscription with its content, configuration files, log files, PHP settings, plus subdomains and domain aliases (if any).
Muista
A target subscription, where you want to move your domain to, must have enough resources (websites, subdomains, domain aliases, or mail names).
To move a domain to an existing or a new subscription:
  1. Go to Websites & Domains, find a domain that you want to move and then click Move Domain.
    image move
  2. Choose where to move the domain:
    • To move it to an existing subscription, select an available subscription.
    • To move it to a new subscription, select Create a new subscription, specify the system username and the password (in the corresponding fields).
  3. Click Save.
Once the moving has finished, your domain will be assigned to the chosen subscription.
Known Issues and Limitations
Moving domains has a number of issues and limitations. Most of them are valid for all moving operations (add-on as well as main domains). Other limitations apply to moving add-on domains only or main domains only.
All moving operations
  • A domain cannot be moved to a subscription without hosting.
  • Only the following users can move an add-on domain to a new subscription and a main domain to an existing subscription:
    • The Plesk administrator.
    • Resellers that have the ”Subscription creation in Server Administration Panel and domain creation in Customer Panel” permission.
  • You cannot move a domain if there is already a domain with the same document root owned by the target subscription. To move the domain, change its ”Document root” value (in Hosting Settings).
  • A domain with mail service cannot be moved to a subscription without one.
  • If a domain with custom additional Apache or nginx directives was moved to another subscription, the directives are preserved and you may need to review them.
  • If you move a domain that has both:
    • A web application installed (WordPress, Joomla!, or any other other)
    • And a Plesk additional user set as the application’s administrator,
    The additional user will lose access to the application. The login and password of the application’s administrator will be changed (you can see them in the application’s settings).
  • If you move a domain with a mail user to a subscription that belongs to another owner, the email address will be detached from the mail user.
  • If you move a domain to a subscription with different PHP settings, the target subscription will be locked.
Moving add-on domains
  • The following cannot be moved:
    • A subdomain without its parent domain.
    • A domain alias without its parent domain.
  • Moving a domain that has a web application installed (WordPress, Joomla!, or any other) does not automatically move the application’s database. It does not affect the website but you may want to move the database manually to the subscription the domain is now assigned to.
Moving main domains
    • A main domain (the domain created at the time a subscription is created) whose subscription has add-on domains.
    • A main domain that has web users.
  • Moving a main domain that has a web application installed (WordPress, Joomla!, or any other) automatically moves the application’s database and database users.
  • Moving a main domain that has the scheduled backup task enabled will turn off the backup task.
  • Moving a main domain will turn off the anonymous FTP access if it was set up for the domain.
  • Moving a main domain that has additional users will detach the users from the source subscription and move them to the target one.
  • Moving a main domain that has scheduled tasks will move the tasks to the target subscription.
  • Moving a main domain that has additional FTP users will move the users to the target subscription and preserve their home paths.
Removing Domains
When you delete a domain from Plesk, all data related to the corresponding site are deleted from the server.
Muista
The main domain of your subscription - that is, the first domain name (default domain) that was created for your account, cannot be deleted; however, it can be renamed.
To remove a domain:
  1. Go to Websites & Domains and locate the name of the domain or subdomain you want to remove.
  2. Click Remove Website or Remove Subdomain.
  3. Confirm removal and click Yes, remove.
Muista
Removing domain names from the Customer Panel does not cancel the registration of these names. If you registered these domain names, you can still use them for your websites in the future.
