L’installation en un clic vous permet de disposer très facilement d’un serveur Plesk parfaitement fonctionnel avec configuration par défaut. Pour ce faire, procédez comme suit :
First, make sure that your server conforms to the installation requirements: Software Requirements for Plesk Obsidian.
Ensuite, connectez-vous au serveur via SSH en tant qu’utilisateur « root » et exécutez la commande suivante :
# sh <(curl https://autoinstall.plesk.com/one-click-installer || wget -O - https://autoinstall.plesk.com/one-click-installer)
The Plesk installation will proceed automatically. It takes, on average, around 15 minutes. The exact time can vary depending on the network bandwidth, the network speed, the server OS version, and so on.
The installer will download the latest stable Plesk release, install it with the default set of components and features designed to suit the needs of the majority of users, and apply all available patches and updates for maximum security and performance.
Do not worry that you are missing out on any Plesk features this way—you can add or remove Plesk components later. However, if you would like to have control over what components are installed, take a look at installing via console or the web GUI.
After the installation is complete, you will need to perform the post-install configuration.
